Racetronix will not provide me instructions/manual for Dual In-Tank Pump System
normally connector A (two wire metripak plug end under hood ) is your primary pump ..that connector gets the mate connector with the wire looped between both terminals so that the relay for it triggers when ecm commands it
the B connector controls the second pump B . normally it gets the wire from the hobbs switch so it only runs under boost
to rotate the use of pumps just move the loop connector at A to B and the hobbs wire from B to A
the other two prong plug under hood is for power led and if not using should have a connector plugged in with no wires just silicone plugs ,
,the kit came with extra terminals and plug ends to add wires to the connector
Dear Racetronic,
You should consider posing all instructions on your website like Casper’s does... easy to find for everyone... just my 2 cents..
Dear Racetronic,
There is a instructional thread on ractronix forum. Some things may have changed but you ask questions and get a pretty quick response.
