Mar 23, 2012 #1 M moyersgn Member Joined Mar 7, 2006 Messages 144 After radiator flush, how much coolant is used to refill stock radiator.
Mar 23, 2012 #2 T TRYMYSIX Member Joined Jun 30, 2011 Messages 459 Depending on your location, most use straight distilled water with some sort of water additive (Redline water wetter, purple ice). If in a cold climate 1 gal of straight antifreeze would work.
Mar 23, 2012 #3 N Nick Micale Tech Advisor Staff member Joined May 26, 2001 Messages 9,208 moyersgn said: ......... how much coolant is used to refill stock radiator. Click to expand... None in warm months or climate like here where it does not freeze overnight. Adding coolant will run hotter than antifreeze, mis-named coolant, than water with an additive like RMI-25.
Mar 11, 2016 #4 N nullrout Member Joined May 20, 2008 Messages 172 So what is the ballpark number? If I have to buy distilled water, how much am I buying?
Mar 11, 2016 #5 626gn Well-Known Member Joined Feb 15, 2009 Messages 2,677 IIRC I usually buy 4 gallons and end up with extra.
