radiator refill
Depending on your location, most use straight distilled water with some sort of water additive (Redline water wetter, purple ice). If in a cold climate 1 gal of straight antifreeze would work.
......... how much coolant is used to refill stock radiator.
None in warm months or climate like here where it does not freeze overnight. :D
Adding coolant will run hotter than antifreeze, mis-named coolant, than water with an additive like RMI-25.
So what is the ballpark number? If I have to buy distilled water, how much am I buying?
IIRC I usually buy 4 gallons and end up with extra.
