SignUp Now!f-gordon, is the f body a direct fit or is there some modifications that need to be made? Thanks.
You will need to remove the deflector used to fit the standard radiator. The core support seems to have been designed for the F-body radiator so no problems with this mod.![]()
There is alot of miss information on this thread. I will post the answer if someone is serious about how to cool a hot air dowm. Check the PIC. Good luck-Brad
I assume you're talking about me. You can speak plain.
I don't give out misinformation. I changed mine over in about 2 hours. It is not a big deal, the dual fan setup I had on a new stock radiator still had me running at 200+ degrees in traffic. The fbody radiator did the trick. The 160 degree t-stat was added later when I changed the intake.
BTW - JEGS has a dual fan setup with an adjustable thermostatic fan controller. Fan can be set to come on at any temp you want. Works great without the 87 ECM conversion.
I apologize for using the phrase misinformation. I should have used the phrase incomplete information. The original post was about cooling down a hot air with an f-body rad. You can do this with the 84ECM and a switch to run the electric fans. You can also convert to the 87 ECM with a chip and have the ECM run the fans. This will require the Casper 84/85 electric fan conversion kit. It works because it takes the electric load off the fans. Some people simply add an electric fan and keep the mechanical fan.
As a final note the fBODY radiator did not cool down my hot air with the stock 87 GN electric fan. I had to go with the dual fan setup as pictured.
Again- I apologize about my mischoice of words. Brad
