I was contemplating doing the same thing and did a pretty good amount of reading on the subject. The general consensus seems to be that radials on the back and bias on the front is ok if you have to do it. Radials on the front and bias on the back is a no no. Also, I think this more applies to cars with similar sized tires. No matter what type of tire construction you run, if you have skinnies on the front it's going to handle poorly and understeer anyway. Taking that into consideration, I street drive mickey thompson radial dr's in the back and 26x7.5 bias ply sportsman's up front. It handles poorly but that's to be expected, it's not a death machine for any reason other than you have half the tread up front as before. I wouldn't necessarily have done anything different if I had the opportunity to do it over again.
