ChrisCairns
Senior Member
- May 24, 2001
Just got home from the track.
I ran a 10.08 right off the trailer....at, get this, 141.08 mph. 1.62 short time. I still dunno if the lights were correct as I've never gone faster than 139.xx.
Next pass was a 10.71 @ 138.50. I had disconnected the MSD 2 step as that damn miss is back with it connected so I didn't have much boost on the line. (I do love the 2 step...it sure beats worrying about not enough or too much boost on the line).
Third pass was a 10.06 @ 139.21. This was with the boost turned up as far as it'll go. More on this later.
Fourth pass I tried tons of boost on the line, still without the 2 step being used, so I blew away the tires. 10.55 @ 138.12.
Final pass I hooked up the 2 step again....wanting the 2 step more than I didn't want the miss. (And sure enough, the miss returned.) I left the line at 3750 rpm which turned out to be the perfect launch rpm as I got a 1.56 60'. I had dialed a 10.15 and slept on the line for a poor reaction time but did manage to catch the guy and let off just a tad right at the top end. Broke out with a 10.135 at 133.86.
These last 3 passes were with the boost as high as it will go and 26 degrees of timing. EGT's on one run were 1896 (yep, no typo) and on the others ranged from 1740's to 1820's.)
Now about the boost. Some of you may remember I had bought a TE72 which turned out to have a 68mm compressor wheel in it instead of what I thought was a 72 mm wheel. I had it redone by John Craig into a 76-Q trim with a .96 exhaust housing. This turbo kicks ass but now I'm wondering if it ain't enough (or cynic that I am, perhaps it ain't got a 76mm wheel...lol) since I was only able to get to 24-25 lbs on the gauge. FAST records 21.x lbs. I know that when I compare the two before I start the engine, FAST will say -1.8 or -1.9, which I attribute to elevation. (I still can't figure where the other 2 lb discrepancy comes from though....and yes, I've switched map sensors and the same 2 lb difference is still there).
Anyhoo, discrepancy aside, I'm thinking about getting an 88/4 bolt. The Chance converter is back at the mfg...so I can have that made to what the bigger turbo would need.
I'd sure be interested in hearing from anyone who runs an 88...or even from those of you who have some thoughts on the pros and cons of this bigger turbo.
Thanks, Chris
Thanks, Chris
