Buick Beginner
Where is my $$$ going?
- Nov 9, 2001
Gentlemen,
I recently received my Ramcharger fans and after trimming the ears and fabricating mounting brackets, I have it installed. It looks, fits and runs wonderfully. I did not order the plug and play adaptor because of the fact that I was told by Ramchargers that the fans would run on high speed all the time as opposed to a high and low speed with the stock fan. I hooked up the wiring using the stock fan's resistor in order to have two speed fan operation. I have a high speed fan switch inside the car and a low speed fan switch inside the car which I had put in a year ago. The switches are self explanatory, each has an LED light indicating when the fan is running regardless of whether or not the switch is thrown (in other words, when the low speed fan kicks on by itself, the light comes on). Now, these are my observations: (1) when the ECM kicks on the low speed fan, both fans do come on and at low speed through the resistor; (2) if I hit the high speed fan switch, it turns the fans on high speed; (3) if I have the high speed switch on and kick the low speed switch on, the fans run at a higher speed than just with the high speed switch on, in essence making a "third" speed. With that in mind, I removed the factory fan resistor and ran the low speed wiring directly into the fan with the high speed wiring. So the way it looks is as follows: green wire on RC fan to high speed in Buick; yellow wire on RC fan to low speed in Buick; blacks both to ground. And here is the way it works: if the ECM triggers the low speed fan, both fans come on pulling a good amount of CFM's. But, whenever the air conditioning kicks on or I hit the high speed fan switch, the RPMs and CFMs increase noticeably on the fans. I said all that to say this: the way it is looking right now, I have a two speed fan set up without a resistor. Will someone please tell me that I am crazy and I don't know what I am talking about, because for all intents and purposes, the fans do run two speeds without a resistor. Comments? - BB
