ramchargers boostcontroller? atr reg.?
87GNcospg
Send your Donations
i can only go from 6 psi(min) to 13 psi(max). what do i do to be able to get a couple more pounds of boost with this controller?
also i had an atr fuel regulator on for aobut a day and then it started to leak and filled my crankcase with gas. who makes good regulators?
You should be able to get 10-12 psi just running a hose from the compressor to the wastegate. It sounds to me like you have some other problem(s):
Header leaks(s)
Boost leak(s)
Wastegate puck not sealing
Wastegate spring is weak
Wastegate rod too long (puck won't seal)
Missing or damaged turbine wheel blades
Tom
Do you have an adjustable wastegate on it?
I have the Boost Commander, and have my minimum set at around 18lbs and can go up to about 25 lbs. This is with alky though.
If you add a second boost solenoid, you can nearly double the range that you have with your BstC. IE, from 6-18psi or so
-DC
I'm still trying to figure out how he's able to only run 6psi of boost??????
Even with a stock wastegate actuator, it's spring is a 12#, so that should be the base boost available.
:confused:
......justa observation..........
maybe there is a reason that about every swap meet vendor at BG had a used ATR wastegate for sell............
