Is it possible to purchase and replace a ele motor on one of these fan units,this fan unit is 4 years old and comes from GBODY ,it has about 5,000 nice weather driveing,but passenger fan motor is starting to squek when i turn it by hand...thanks
Are there any relays to add for a JEGS FAN ,please explain ele twin connector hook up to gn fan harness....I have a twin relay caspers harness can it be used..thanks
Thats what i did cut the RC fans end off the caspers kit and tied in the harness to the Jegs fans. They come with a male/female pig tail. Also added the dealy module from caspers to one fan to delay its turn on 3/4 of a second to help with the inrush current. Real nice set. Even with my FMIC, Condensor and the big GN1 extreme radiator the fans will suck a plastic grocery bag from 6" out to the grill and hold it there!!
Those fan motors are pure cheap junk go to a junk yard and get dual fans from a taurus or lincoln they are 2 speed,never go bad and pull more air than the ramcharger-dodge fans I'm sure you can adapt your wiring harness.
