Random Clicking When Driving.
turbo_dreams_85
itsaV6howcanyoulose?
This Just Started About 2 Hours Ago, Hence Why I Noticed It. I Counted It Out And It Happens Every 8 Seconds, It Clicks And Moves The Speedo Needle. Any Input Is Amazing!
Thank You TB.
Ren
P.S. Here's A Video Listen For It At 14 & 27. That's When It Clicks.
Thanks Again
could be a sticky speedo cable? pull the dash back and spray some lubricant down the actual inside of the speedometer cabel. Happen to me before that fixed it.
The speedo cable is a two piece cable. There is a connection under the hood by the master cylinder. If you can separate it there and lube it, it would save you from tearing onto the dash
David
87GN
