Rarest TR Option??!!
hello people; just to come back to that seat option a T could have and it's called Lear Siegler option. thigh support, back side(wings) support,lumbar support. I don't know if it" combined with the six way but it sounds nice.
Also that twin turbo is real nice.
IBBY
That seat option was available on the 84/85 cars but not the 86/87. It was on the original 86 order form but was discontinued before any cars were built.
Mike
You must have been looking at a Riv than. The T-top cars have the dome lights in the 1/4 trim panels since there is no room on the roof for them. They are round and almost 2" in diameter.Astroroof and solid roof cars could have option C95 which is the dual reading lamp option. No bug eye option ever offered on the Regal.
Found another set of BUG EYE interior lights in an 86 REGAL today:) The car is a hardtop limited.....Rarest option I know of..
My 86 T has bench seats, a column shift, no posi, power everything but the bench seat, T-tops. One of the salesman at my dealership (GM) was selling cars in the mid 80's. He was saying that most dealership would only get a certain number T's and GN's per year (Canadian) Other than the few that ordered one, most were pre optioned and sold as is. He was saying that GM ran out of the buckets and consoles and they just threw a bunch of bench seats and column shifts in just to get rid of the extra stock they had. He said in the years of the GN and T, he'd only seen 6 cars with bench and column. All were 86's and only 1 had T-tops. I though that was kinda neat. I hated my bench at first but I actually kinda like it now because I've never personally seen another one like it.
86 BUICK REGAL GRAND NATIONAL T-TYPE
1G4GK4777GPxxxxxxx
3.8L TURBO V6 SFI
COMPLETE OPTION LIST
AG1- adjuster, front seat , power 6 way, split bench
AS7- seat , front split
AU3- lock control, side door, electric
A01- window tinted, all shaded, w/s
A31- window, power operated, side
BC3- ornamentation, intr, instrument panel, deluxe
BD1- ornamentation, exterior molding, rocker panel--DELETE
BS1- insulation, acoutical pkg
BV6- ornamentation, extr lock cylinder, painted
BV8- ornamentation, extr dr handle, lock cylinder
BX5- ornamentation, extr mldg, roof drip, painted
B24- ornamentation, extr mldg, side window reveals black
B26- ornamentation, intr, dr pull handles, frt
B32- covering, frt floor mats aux
B33- covering, rear floor mats aux
B48- trim equipment, luggage equipment
B71- molding wheel opening, colored
B72- ornamentation, extr mldg belt reveal, colored
B77- ornamentation, extr mldg w/s reveal, colored
B79- ornamentation, extr rear end
B88- molding body side custom
B89- ornamentation, extr mldg, rr window reveal
B91- ornamentation, extr mldg dr edge guard, colored
B94- ornamentation, extr emblem, body, var 1
CD4- wiper system windshield, pulse
C18- arm & blade WSW
C60- hvac system, air conditioner frt man controls
DE9- console, frt compt, non shifting
D35- mirror o/s, LH rem cont, RH direct cont, painted
D64- mirror i/s, RH sunshade, illum
D71- gear, speedo driven (p/n 25524925)
D85- stripe, body side lower accent
E5Z- Speedo adapter delete (analog gauge cluster only)
FE2- suspension system, ride handling
FFL- Flint, Michigan, body plant #1
GQ1- axle, std ratio
GU6- axle rear, 3.42 ratio
G80- axle positraction, limited slip
G87- ring gear 8.50 inch
K09- generator, 120 amp
K34- cruise control, automatic, electric
LC2- engine, gas 6 cyl, 3.8L, SFI, V6 TURBO, High Output
MW9- transmission, auto 4 spd, THM 200, conv clutch
MX0- merchandised, trans, auto provisions, O/D
NB2- emmission system, california, tier O
NP5- steering wheel, leather wrapped
NQ5- cap, strg wheel horn, deluxe
N33- steering column, tilt type
N89- wheel, turbo aluminum
PON- Pontaic, Michigan assembly plant
QYH- tire all, P215/65R15/n wol r/pe st tl hwy
TL6- Grille Black
TL8- ornamentation, extr mldg hood (3.8 SFI turbo)
TT5- headlamps, tungsten quartz halogen
T47- hood turbo
T83- headlamps, dr, special
T93- lamp, tail & stop, special
UA1- dual rear speakers
UM6- AM/FM stereo with cassette
UQ1- radio provisions for stereo
US7- antenna, power, painted radio
UW4- speaker system, 6 dual frt dash mtd R/D
U23- cluster, inst, trim odom
VA2- radiator support steel
VD6- bumper provisions, frt, aluminum
VD7- bumper provisons, rear, aluminum
VJ9- label, emmissions, calif compliance
VK3- lic plate, frt mounting pkg
V73- Antenna, Fixed
WG1- Sales, processing for driver power seat (6 way)
W11- T-type package
YF5- California emmissions test (pre sale-no cost)
YS2- Rear Seat Deluxe
YT9- option package, fisher furnished parts
55A- stripe color, accent, gold (91)
6YT- component frt LH computer sel susp
62I- interior trim, light saddle
62U- primary color exterior, LT beechwood met (91)
623- trim combination, leather, light saddle (3)
629- trim combination, seat belt, light saddle
7YU- ??? maybe battery type???
8HP- rear spring-left
9HP- rear spring-right
Another weird thing. The car has NO history prior to 1990.. dmv shows it processed for the first time in 90. Autochex shows it titled in 1990.
The car was parked at a storage facility in 1994. Processed as non op with California dmv in 94. I just bought it in feb. I'm in the process of getting it started for the first time since then. The car is 100% stock. No modifications. Original tires were on the car and rotted out. Original brake pads on the rear drums too. It's missing the turbo shield.
The worst part was that it was left in the sun for 21 yrs.
A bunch of mods under that hood! Hoses on up pipe are aftermarket, boost hoses and T coming off the wastegate solenoid are INCORRECT.
And look at that monster hitch that someone added!
How many 1987s have a factory astroroof and power driver's seat? I was told it wasn't an option on later build cars? Mine was built in December of 86. Also, how many cars had the twilight sentential option.
I'll post up better pics. I'm not an expert on these things. It's my first. Thanks for the help.
What's the second port for? Mine has 2 lines from the turbo one into each port
I'd love to see a pic of the spid label on this car. Should have a WO5 and WO2
As far as rare options I was made to believe a block heater is pretty rare.
What is a "spid" label?
The spid label is the white tag with the option codes found under the deck lids of turbo regals and other gm cars produced in and after 1984.
Looks like this.
Here it is. There's 2 of them on this car. One over the plasticized one.
