chopped39
- Aug 30, 2004
I know, old thread. I've been getting a thump which only happens with a passenger in the car. It happens over small bumps in the road. Or large bumps too. I thought it was from around the transmission area. Drive shaft doesn't seem to be hitting, nothing in the rear appears to be hitting. All upper body bushings are in place. Put car on lift and mechanic found a nice clean spot on the rf coil spring where it was rubbing against the frame. I don't see how that could cause a thump but what do I know. He is certain that is the cause of the thump. So I dropped the shock and spring to reposition the spring and found out the Monro sens a trac shock is completely dead. When I pushed the plunger in it does not come out at all. I haven't inspected the other shocks yet but I ASSume they are on the way out too. I installed them in june 2011. They were cheap, about $20 each if I recall. Should shocks wear out in 3 years and maybe 25k miles? I just bought 4 kyb shocks at Jegs for about $35 each. This is 1/2 the price that Advance and AZ sells them for, plus no tax and free shipping. My mechanic says 3 years is all you get out of shocks these days.
Is the car stock height? If it is lowered the sensitrac will not work properly and will wear prematurely . The valving is set in the shock at a desired spot depending on application. When they first came out they were decent and then they went to shit. I worked for Midas when they dealt with Monroe and over time the quality went away. They wanted the shock inspected every 12k. If I was taking them off to inspect them they were bad.lol. I put a set of Monroe response shocks on my 95 century and they were leaking in less than a year . Who did you buy them from. Midas was giving life time warranty on sensitrac shocks and struts back when I was there. I ran them On my Limited and it road pretty nice. My whole suspension was moog at the time.lol
