Rattle kit for window
carguy
Which of these parts are used for the anti rattle kit? I know not all of them are used and am wanting to know which ones are used
BOB, CHECK YOUR ROLLERS ON THE REGULATOR TRACK,MAKE SURE THEY ARE TIGHT AND NOT WORE ON ONE SIDE. THEN CHECK THE UPPER ,TOP FELTS ON THE IN-AND OUT ADJUSTMENT(THAT HOLDS AGAINST THE GLASS, ARE THE IN GOOD CONDITION? IS THE REGULATOR ITSELF TIGHT?..MAN IF YOU DID NOT MOVE SO FAR AWAY, I WOULD BE GLAD TO GO THROUGH THE DOORS AND ADJUST THE WINDOWS.....SOOOO BACK TO YOUR QUESTION , THE ONE ITEM WIT HTHE FELT ON IT IS PART OF THAT KIT THAT USUALLY NEEDS REPLACED, THE ROLLERS ARE COMMONLY WORE.. IF YOU NEED ANY OF THE FELTS-OR INNER DOOR BRACKETS, LET ME KNOW.. I HAVE SEVERAL(OFF A 36,000 MILE REGAL)
