M markboss Member Joined Dec 1, 2002 Jan 8, 2010 #21 Check the intercooler bracket on the psgr side, where it bolts to the block..... The bolt might be loose..
S Smokin-6 Member Joined May 11, 2007 Jan 8, 2010 #22 510TURBO said: changed the water pump, my pulley has a little play in it but the worst news is that sound i been searching for is my rod bearing Click to expand... How did you determine it was the rod bearing?
P PLAINWHITE T Tree peddler Joined Jan 11, 2010 Jan 19, 2010 #23 Before tearing into the lower end, just for giggles check the torque converter and flywheel bolts. They can occasionally mimic a bad rod or main bearing! I hope you luck out!
