Rattling sound after braking hard-
V6Turbo
Driving around 55 MPH, a driver cut me off and had to brake hard to avoid accident. Now GN rattles as the tire spins. Frequency of rattle is consistent with tire rotation speed.
Have to lift the car to figure out what is going on, but am at work right now. Any known issues before I consider driving it home?
Thanks in advance...
dont know if this will help, but my exhaust is a little loose and rattles when i brake, so you may want to check that out
It's also possible that the center cap on one of your rear wheels is a bit loose. Take them all off and drive the car. If the noise goes away, you've found your problem.
Now Speedometer not working
Just checked and no problem with Center Caps.
By the way...the rattling sound went away as I tried to inspect with a friend. Did not find anything on the ground that fell off the car.
Funny thing is now...my speedometer is no longer working...just stays at 0 same with Scan Master.
Checked cables but still in tact...Don't know if this is related to the earlier rattle.
