Ahh...
So that's why when i called to order some blues for a direct in a 200 several weeks ago you didn't want to sell them to me...
Chris,
I've never really messed with the blue plates, only big time trans I've messed with was in a monster truck and I believe it had blues, but other than that no BIG power output. Under 800hp is what I will consider "small hp"
I just did a midnight thashing to piece that trans together so didn't pay that much attention and really didn;t know the difference at the time.
I will say that in my limited experience (compared to you gurus).
I've been VERY impressed with the Alto Reds.
I'm hard to convince of these types of things, I want proof, not a vendors propaganda.
I built a TH350 for a buddy several months ago, probably over a year now.
He is running a 3600+ lb '75 Camaro with a pretty stout 383 plus the N2O. RWHP is around 550 if I recall correctly on the juice and the torque is over 650.
Anyway,
I had a pump bolt break off on assembly (last bolt in the trans deal...)
So I had to remove the pump, reinstall it, remove it, etc.. to attempt to extract the bolt, use the pump to line up a drill bit, etc...
Anyway to make a long story short I probably cracked one of the forward rings. (I know I use Teflon now...)
He drove this thing for months, wheels up action, 10 second car on the bottle.
finally was driving home after a nigh at the strip and it started to slip in all forward gears. He drove it over 20 miles in city traffic babying it to get it home.
Pulled trans and called me.
Had him bring it to me, already expected to see toasted forwards.
Pulled it apart and as expected the ring was broken, forwards were burnt, BUT, for the amount of driving he had to do to get it home and as bad as he said it was slipping, I was very impressed that the clutches were as intact as they were.
In truth they would probably have still functioned fine if installed on a new set of steels and with proper pressure to the forward drum. They were pretty blackened but not anything like a set of OEM clutches woud be.
So I was inpressed.
I was sold...
Also,
TransGo (I know nobody likes that name here, but...)
states that in a TH400 a "used stock smooth friction is as good as it gets". Performed better than blues in their testing.
I believe that was before the reds were available.
Also on Alto USA's website,
they show "independant" lab tests on theirs versus other OEM style frictions.
Interestingly the 2 frictions they used (I'm guessing Rays and BW's) one (guessing BW's here) were only slightly less effective than the reds.
I would think for marketing they would try to show a larger difference between a OEM and their own product but I'm guessing it is a pretty good indication of truthfullness in advertising for a change.
In most of my builds (mostly TH350's and 400s) I use BW's. If a customer wants I use the reds.
I haven't had ANY problems.
Actually when I warrantied the above TH350 I put BW frictions back in because I had them on hand, and cannot easily order the reds in individuals, I have to order a set for a complete trans.
Really throws it off when I'm putting 5 in the directs
Thanks for the info,
Jake
