razor install problem
Oz08
I installed razor's progressive alcohol kit and something went wrong somewhere. When I hit the test button the pump beeps, the power injection light doesn't come on, and the car won't start. HELP!
The power injection bulb is wired across the pump wires. It has nothing to do with car not starting. Pump beeping is normal when you hit the test button.. and the bulb should glow when the pump makes a sound.
Now I wouldnt be testing an alcohol kit without the engine running. Actually there shouldnt be any liquid in your tank after the install.. then you do the tests.. then you add alcohol.
As far as the car not starting.. not enough info. I mean does it crank over? Does it have fuel pressure? Does it have spark? Does your "check engine" lamp illuminate? Your scanmaster numbers normal for a non-running car? etc.. You can shut the alky kit by placing the knob on "Off". And troubleshoot why it doesnt start. I bet you unplugged the ecm connector by the battery when installing your tank.. thats my bet.
All the numbers looked normal and it does crank. I didn't check the fuel pressure but it was getting fuel. In the instructions I thought it said to hit the test button with the key on after install. I haven't put any alcohol in yet. When you say the bulb should light when the pump is running do you mean the power injection bulb? I can't look at it until tomorrow around 5:00 central, but will you be in tomorrow? I'll check the ecm connection and spark as soon as I can.
