87gnblackdemon
Don't Be Redikulas!!
- May 24, 2001
Does a BOV need to be re-routed to go back into the intake?? I read that dumping the air into the atmosphere is not good for our cars;
"putting a blow off valve on one of these cars is more complicated than just welding it into the up pipe or the intercooler and putting a vacuum line on it. since these cars measure engine load via a mass air flow sensor--you will be running way too rich when you let off the throttle. this is because if you vent all the air in your pipe out into the atmosphere thru a blow off valve, your computer thinks all that air is still in the manifold--making it run really rich."
Like you do in most BOV questions... Don't tell me I don't need one cause I didn't ask.
