carryon525
- Feb 22, 2016
SignUp Now!I had to research pretty hard but from what I found that BOV is an old school HKS racing one and is pretty damn cool a lot of BOV fans seems to really like itThat looks nice! It should look real good in your engine bay, even with that big ole honkin' BOV.
Gn1Where did you get the scoop?...thanks Mike
Here you goHmm... I'm not sure how that valve works from the pictures. Can you post another picture that shows the side profile of the valve & both ports?
Yes it is a port just no hose is or currently was on it. The boost vents to a large opening on the other side which is not pictured.Is that lower tube actually ported? Judging by the patina, it does not appear to have ever had a hose mounted to it.
Where does the excess boost vent to atmosphere through that valve?
I'm thinking that valve has a top mounted spring loaded disk inside. It looks like that threaded post at top center allows you to adjust the tension on the spring. Tighten it for more boost & loosen it for less. The excess boost has to vent somewhere. Is there a vent port in the valve body that is not shown in the pictures?
No its an OLD one. All Ive been able to find is that is seems to be a really good one and sounds really good. Just can't seem to get any firm anwsers on how to hook it up to workIt may just be a valve body vent to atmosphere to allow the disk to move. It's hard for me to tell without being able to handle it & check it out.
Any info available on an HKS site?
