OK this is my situation currently my car isnt performing as advertised. IM not sure if its my Coil Pack or something else. Currently i have an 84 T-typ and when ever i get in the throttle too fast the car will start to sputter and die out ... it wil jerk and kick and miss really badly, not only that but the seat belt light turns on when this happenes then goes out when it stops. I can ease into the throttle slowly and it will be fine but as soon as boost starts to come up it will start acting up again.The funy thing is when the car is in park or neutral and you rev it up it sounds fine with maybe a slight hint of a miss or too. The wires had been testes with and osillascope and 2 of the wires where spiking way too high. I was told it was either the wires or the coil....so i changed the wires and here i am now... The TPS is good as far as i can tell it was set as close .42 as possible it jumps from .41 to .43 but no .42.... I want to know could the ECM cause this problem.That reminds me there are no Check Engine lights either so what does that narrow my problem down too??? Any info is good info if it can wake my monster
