S
SLOS-10
Guest
For some reason, my car just will not pull hard. My last GN pulled like a mofo. Turbo just doesn't seem to spool fast in first gear. Spools real quick when it kicks down into a lower gear, but is an absolute dog @ wide open throttle. I opened the exhaust thinking it may be that crappy flowbastard stock style exhaust...no such luck., better, but nothing to write home about. I have a scanmaster and everything seems to be ok on it. All readings are right about where they should be. I have run two different chips in it. A thrasher 92 and a jay carter 93. Still get a little bit of knock when the boost spikes up a little. LIke I said, 15 psi just does NOT pull at all in this car for some reason. I know that is low boost, but a well tuned stocker would put an absolute aZZ whoopin on this car.
Stock turbo..868's, adjustable wastegate, K&N filter, stock location flowmaster.
I've also noticed some oil up around the vacuum block. seems like it leak sor something around the bottom of the block.
Please help!! thanks
