grocerygetter
- Mar 8, 2005
I just put new brake all around and the bigger S-10 wheel cylinders on the car...it stops great.  We dialed the rears in like you would normally.  You can tell they grab harder but it's nothing crazy.
Now for adjusting them....
right now, you can set the ebrake, put it in gear, and the car won['t go anywhere. But, if you give it a little gas it'll pull forward slowly. How tight should the rears be so that I can build some boost and launch this pig?
