Jan 10, 2007 #1 M madhat New Member Joined Nov 27, 2003 Messages 1,356 So, what kind of socket did you use to get that thing loose? My sockets are too thick walled and I cant get them to fit in the hole...which also renders wrenches worthless.
Jan 10, 2007 #2 salvageV6 Daily Driver Joined May 25, 2001 Messages 21,009 The obvious answer you know is a thin wall socket. I use a Sears long 1/4" drive one. Use lots of PB Blaster on those things first. Just had to replace a rusty cylinder because of a stuck bleeder, was worth it though as the thing was pretty much rotted away. Once loose I just run the clear hose down the socket and use a vise grips to open and close it for bleeding. Mechanics and shops have special wrenches and sockets that seem to fit it well enough, specific brake tools.
Jan 10, 2007 #3 M madhat New Member Joined Nov 27, 2003 Messages 1,356 I know the answer was obvious, I was jsut making sure that you didnt need some super-special-GM-tech-exclusive socket
