Carl,
I think the broken axle is an anomoly. (However, you have been more consistently launching hard the past few years than most I would say). Carl races his car often enough. Since the moser's "should be stronger than stock", wouldn't they last you even longer than these?When you put in the mosers, you can use stock length studs. But be sure to tack weld them in place as they will loosen up over time.
Save your $ on "this" car unless there is more broken than just the axle. If there is nothing else wrong, obviously it was just the axle and the carrier wasn't moving around on you. If there's more broken, then that's another story.
