My rear main is leaking, what a suprise. Is there a rear main oil seal that is out there better than the stock rope a dope seal? I saw Kirbans has a 2 peice seal but didn't know if it was any good, or a better one is avail elsewhere.
I'm sort of at the point where I need to do a bit of work, Oil pressure sucks, (got a cover kit for that) oil pan leaks, rear main leaks. I realize these cars always leak a bit but I figured I would try to lessen it. My tranny is empty right now because I just had to do the TCC from the wiring shorting out on the metal retaining clips inside the tranny. It looks pretty simple so I was half way thingking of doing it all at once. Unless of course the rear main will leak no matter what, in which case I won't bother.
For reference there is usually about a 6 inch trail of oil every time I park the car for a week after a drive. It's not my daily, just the weekend warrior?!
Thanks for your input.
