Does anybody have the dimensions for DIY rear seat bracing.
I would like to know the length of each pipe, dia. of the pipe
and type of pipe used.
Thank you
I used 1/2in. either black or galvanized water pipe, galvanized better. Each side has a 25in. long piece and a 26in. long piece. You'll see because of how they bolt in. Flatten the end of each pipe about 1 1/2in. You'll need to bend one in the middle to clear the other pipe cause they both bolt to the same flat surface. You'll see when you go to bolt them in? You will need some 3/8th bolts about 1 1/2in. long, flat washers, and some nylok nuts, you're all set. Good Luck Dont forget to paint em.
Tarey D.
