I just installed a Moser 9 inch Ford rear end. The upper control arm mounting wings seem to be a little taller than the stock rear end. This causes the rear end to hang down a little lower when rhe car is put on a chassis hoist with the suspension at full drop.
What happens now is the rear springs drop out of their upper spring seats and dislocate. When I let the car back down on the ground the springs are not seated in the frame saddle correctly.
Looks like I need springs about 1 inch taller in the non compressed state to fit snuggly between the axle perch and the frame saddle.
I've got a brand new set of springs so they aren't sagged.
Has anyone experienced this problem before ? and what did you do to solve it ?
Anybody got a website that will give me rear coil spring dimensions and spring rates ?
Any ideas or help on this would be very much appreciated !!
George
George
