Ok, I can't say what is best for your needs, but I went with fully adjustable BMR uppers with good spherical rod ends at the frame side, and factory rubber at the rear, and Global West lowers with the spherical rod ends on the front side and Del-A-Lum bushings at the rear. Not for the faint of checkbook. About $320 or so for each set. Adjustable uppers are nice, but probably not necessary for your needs, unless you want to impress your suspension shop. If I was to set up another turbo brick suspension, I would do the same all over again. HTH
