Hydroboost Vs Vacuum Vs Powermaster
We Used To Convert New S10's For The Dealers From Manual To Power Brakes In 1985. That's When We Found Out The Difference In The Wheel Cyls. When They Are Converted To Power Brakes, The Rears Would Slide The Tires. Converting To The Smaller Cyls Was Necessary. When We Saw The Buicks Burning And Cracking Rotors, We Went The Other Way For The Buicks To Increase Rear Brake Power To Balance The Chassis. This Was Also Something We Had Done With F350's, Motor Homes, Etc. Because They Were Burning Pads And Rotors Sine 1971. The First Buick We Did Was In 1987. We Set Up Art Carr's T Type That Way, And His Motor Home. Now We Do The Suburbans, Tahoes, 4x4's, Jeeps, Etc. Increasing The Rear Brake Power Pulls The Chassis Back, Lessening The Toe-out Stress On The A Frames. Rotors Crack From Overheating. The Bigger Wheel Cyls Reduce Rotor Heat
