No disintegrations
- Dec 27, 2015
Yes need wheels on, or thread on some open face lug nuts.
SignUp Now!try it at stall/boost?After running it in gear for awhile I step on the brake and it always stops the wheels from spinning, th
I knew what you meant. Some did not follow however.I think I might've not been clear, I wasn't trying to hold any boost while in the air. I just had it drive and tried pushing the brakes to stop the wheels from spinning. And they would continue spinning. And on the road test around the neighborhood is when I tried holding boost on the footbrake and had no success. Wouldn't even get to 0psi
chuck leepers response is basically what I was trying to say so I hope you understand it now.Im sorry but this makes no sense. If it cant hold a 30 pound wheel still how can it slow down a car?
i did the first time, you and chuck went on the wrong trail and we were talking about different things.chuck leepers response is basically what I was trying to say so I hope you understand it now.
Your probably needed to adjust the rear shoes. They were probably loose, but I also wouldn't be surprised if you damaged the rear wheel/brake cylinder being that the drum fell off and you probably were able to over extend it.
