rearend/axle question.
Ziptie86
The scaffolding man!
Hey guys, I need to replace the wheel studs on GN. I was wondering how hard it would be to remove the axles so I can get some longer studs in there? Maybe a quick step by step. I know it has an auburn locker....so is there anything I need to know about it? or is it as simple as pulling the c-clip and removing the axle? ALso do I need to do remove any of the brake components? Thank you,
Jamin
theres a center pin going thru the posi unit and a little bolt going thru that pin sideways at one end of the pin
take the little bolt out and slide the center pin out then push the axles in a little bit and remove the clip from the axle in the middle where the pin was
once c-clip is off axle will slide right out
pretty easy
reds hot air is correct....a little thing that helps when removing the c-clips are a mag pickup tool.
Is it possible to remove the wheel studs without pulling the axle? I seem to remember that there is a hole in the brake backing plate just for this purpose. You have to line the stud up with the hole, then drive it back through the backing plate. But I may be remembering a different rear axle... my memory is a little cluttered.
There isn't a hole but you can slide the stud up through the brake shoes. I would pull the axles and press the new studs in on an arbor press that way you dont screw up the threads and stretch the studs.
I have my 87's rear brakes apart -- there's not a hole but there is a fairly deep enclosed pocket or recess in the backing plate.
There is about 3" clearance betrween the axle flange and bottom of this pocket... it looks like even a 3" Lg stud would just fit.
Looking at the arrangement, it appears the studs "might" be removeable from a fully disassembled rear brake, by using a C-clamp to press down on the stud, and a short hollow "receiver" (a socket maybe) behind the axle flange, for the head of the stud to pop into. It would have to be a heavy duty C-clamp, with a wrenchable thread.
Snapon & Matco make tools for re-installing studs, although I suspect one could improvise with grade8 nut & some flat washers.
