SignUp Now!20 minutes running time at 2500RPM +,
very the RPM (rev it slightly) every 2 minutes...
After that she'll go or blow (rollor or flat tappet)
Good luck
My bad, You meant total break in,Do the above, then drain the oil (to rid the cam lube,assembly lube, break in low weight oil),replace with fresh an new filter, then go for a drive an seat everything,heard it's best to very your speed every 10 miles for the first couple hundred miles
Enjoy!
