Recessed tip spark plugs???
i use the AR3933 in alum heads. I have tons of street miles and race miles on them.
ill pick up some 42's just for the track & keep my 43's in for daily driving.. What gap are u using? Most say .32, i think mine are currently set to .40. Thanks for the replies..
Most go around .032 for stock boost levels, then close the gap to about .028 when running 30#'s.
That was me who melted the tip off the autolite
Maybe the .035 gap @30psi was a lil much
What plug (cylinder)? What fuel pump? Running Alky?
Not the pug gap that melted it.
I run a .040 gap with a TR6 box and NGK UR5's at 30psi with my little blower and no problems. The wider gap makes the lean cruise run smoother too.
So I need to change to projected tip plugs for road trips and recessed plugs for track. :)
You should keep IAT in your thought process when selecting plugs too. Ambient temps, charge air temps, etc..
ok so what do yall think about staying with the r43ts with a 35ish gap on street boost which is 14-18psi with 93 & street tt chip & changing to 42's with a .32 gap @ 25-27 psi on track day with a race tt chip?
My father use to be a outboard motor mechanic back in the 70-80's. If I remember correctly, Champion made a plug, for a Johnson, that had no tip at all. I've always wondered how it would work in a turbo buick being as we have to close our gaps in order to keep the flame from blowing out. Also along with not having a electrode poking out in the combustion chamber thus creating a hot spot. The outboards would use them because of poor ignition system and trying to light off the fuel mixture with the 2 stroke oil. Look at the very bottom of the link, it's called surface discharge or surface gap. http://www.ngk.com/glossary/8/spark-plug/S
Same type plug they use on light aircraft engines. I have no idea why but they usually redline well below 3,000 RPM.
