red brake light is on .......
cecil bass
The red brake light on the dash is on and I don't know why or what i should do to figure out what's wrong or how to turn the light out .
On or comes on when you press the pedal? Sounds like a possible accumulator ball failure if its still the factory power master set up
make sure the e brake pedal is not down a little, and no air in the lines, low pressure will set it off too
