Red stripe torque convertor
The red stripe torque convertor should be a 2800 stall. It all depends at how much lbs of you com out at. For example this is the torque I am using in my car, and when I crank the boost up to 5lbs the torque stalls at about 2600. When I Crank the boost up to 9lbs the torque stalls at 2900+ rpm. I haven't tried more than 9lbs of boost, but I did my best 60ft this way.(1.52)
86 Grand National t-top (59000km)
stock long block,stock suspension, red stripe convertor, te44, smc alk injection, 24lbs boost, 94 octane, hooker cat back with dyno max ultra flow muffers, tomco 30lbs injectors, dyno stage 4 street chip, thdp, mease 24 row IC, MT drag radials (275/50/15) 3800lbs race weight.
best ET
60FT=1.52
1/8= 7.38
I/4= 11.74
MPH=113
BEST MPH= 114
