Reed cam
derrick
i had a reed cam installed into a motor had had rebuilt, my question is do i need longer push rods for it or can i use stock lenght? the cam is tm252h-10a1. im also using kirban stiffer springs. can anyone help me thanks
Get an adjustable pushrod adjust it to obtain the proper raocker arm to valve tip geometry.
Once the geo is correct then order the size pushrods needed
