I have a TDC ref i set when the motor was on a stand. Now i use that with a timing lite and see 7Deg difference between what felpro says and my lite. I set the ref angle at
3.0 instead of 10 and the lite and the felpro are the same. The only question i have is when using a lite with a dial on is the timing half of what the dial says because of the type of ignition and lite i have?(2 plugs firing at the same time)
