v8skantkeepup
- Dec 17, 2004
I own an 85 T-type that I have just had repainted. The origional paint wasn't real bad, just faded on top. Probobly cuz no clearcoat. Anyway, when the body shop started working on the body, the guy doing the work gave me a call one day and told me to swing by if I had time. When I arrived, he showed me a small crack in the drivers door (about an inch long)under the paint, where he had been sanding. The crack was in the door skin itself, about in front of where the mirror bolts to the door. You could accually push on one side of the crack and expose it without any problem. I was dunfounded. The car was baught with 48000 miles from the origional owner in 98'. I was under the impression that the car had been stored inside, from the condition, as well as demiener of the older gentleman I purchased it from. The car currently has 76000 miles.
This sad story is not over. The bodyman assured me he could weld, and smooth it so nobody would ever know... The very next day he called me again and said "Your not going to believe this, but, the passenger door is cracked in the excact same spot!!" WTF!! I thaught. I even went to a few local boneyards in the following weaks and eyed some other G-body's to see if this was common and like half the doors I looked at were cracked as well.
Whats up with the shoddy metel?
Weak spot in the doors?
What?
GM has to be aware of this. Am I the only one to notice?
This may be of interest to those looking for clean used doors.
Just for the record, my doors are rust free. They look untouched, now that the car is finished. But I know whats under those two particular spots of paint. This is scarry to me!!!!!!
Anyone share this expierience?
What?
