removing center support from direct drum
ThatDamnFox
How in the world do i seperate them? Am i missing something stupid. Is ot pressed on? I know how to do everything else but cant figure this out. 2004r of course
Do you have the two bolts under the valve body removed? And the retaining ring at the case?
Or you have them out and having probs as Mr t nasty asks?
The ring seals on the center support probably cut into the inside surface of the direct drum making it hard to separate them. You may have to pry them apart. Shouldn't take too much force to get them apart. It's a common problem. :)
