Removing cruise control
blackgn1
Set on TSM Boost
Got all the cruise control removed and I'm left with a large vacuum line. Where does it go? Looks to run in the fire wall. What was this line for?
There is a vacuum switch on the brake pedal that brakes the vacuum to the cruise control actuator. You can remove that switch and the vacuum line also.
it's easy to find- it's the switch on the brake pedal that has the big vacuum hose going to it.
