SignUp Now!My 86 isn't exactly a concourse restoration, by any stretch. The EGR stuff on the driver side valve cover is disconnected. The switch thingy and the other big thingy. What other EGR stuff and get disconnected and removed?
Okay, I figured out where the block of plate goes on the manifold. I removed some stuff which I think is the egr, but wanted to make sure. Take a look at the picture and let me know.
What did you guys do with the electrical connection from the back of the motor to the egr switch? How about the vacuum line that runs along the firewall to the egr switch? How about the other vacuum and electrical lines?
Thanks.
Thanks.
okay...the item in the upper right hand corner needs to go back in and get hooked up. I need to know where the two vacuum lines that hook to this upper right item go to and from? one was disconnected when I got the car. Thanks.
Just went out and checked the compressor side on the turbo. The vacuum line on the compressor side is going straight to the adjustable waste gate solinoid. I think they call this the 'tuner' style of hooking it up, and it's supposed to be pretty slow. Can someone give me some guidance as to how I should properly set this situation up. My spool up is dog slow and I'm trying to get my vacuum lines routed properly. Thanks.
I wouldn't even know where to begin to look for that "T".
edit-okay, found some great information and pics here:
GN and T-Type Performance Enthusiasts (GNTTYPE) Forums - Sensor question
Thanks for the help!
Guys do any of you run the EGR solenoid and just plug the lines? I have a champion intake with EGR removed and FAST sequential system.
