Removing Valves
MiamiGranny
How do you remove the valves and valve springs, ive got a set of heads laying around that i want to clean up. can someone help me out? post a link or just explain? your help is appreciated.
:confused::D
Just run them over to a machine shop and for a couple bucks they'll remove them in about 3 minutes
Thanks a lot guys, i never knew it was that easy to remove the valves with the tool. Youtube works wonders LOL, ill take pictures and post a build thread when i get all the parts i need.
If you do remove the springs and want to pull the valve hit where the locks rests (upper land) with some 800 sandpaper to remove any burrs so the valve will slide out through the guide without gouging it
