Vehicle select: 0 or whatever is the correct setting for GN.
#of Cyl: 6
Displ: 3.8
Airfl Srce Speed Density
Map Source: 0 (GM 3 Bar Map)
Load Source: This I'm not sure about but if I were to guess. the Use MAP setting
Baro Mode: Also not sure. (No BARO mode) maybe.
F-out mode: 8 (for GN with extender pro chip)
V-out 1 and V-Out 2: Not sure 2 for Map 3 bar maybe?
AFR source: Don't touch since I don't have Wideband?
F-in, Aux1, and F- out don't touch?
Also the Extender Pro will have the base settings preconfig right so I won't have to mess with that until I'm ready for the fine tuning?
You can set baro mode to: capture at key on
V out 1 to: 1 (send timing signal to ECU) controls wot timing
V out 2 to: use set point
F in to: 0
