I'd like to install new crankshaft bearings w/o removing the crank. Cam lobe partially gone and old bearings don't look too bad but figured I've gone into it this far and for what they cost I might as well put new bearings in. I think there is some kind of tough plastic or nylon tool you can use to remove the upper bearing half. I believe you insert it into the crankshaft oil hole and rotate the crank from the oppposite side of the bearing lock and it pushes the upper bearing half right on out. You can then reverse the procedure using the same tool to install the new upper bearing half. Has anyone ever heard of this or done this and if so do you know where I might purchase this gizmo?
