gpadilla1071
- Jul 30, 2007
Hi all, I just replaced my front rotors (very much needed).  My questions is should I hand tight the middle bolt or should I tie it with a socket wrench?  Is it suppose to be a little loose or did I do right right thing by tighten them up nicely?  I drove the car and didn't feel and different, just a little smoke came out, but I assume is because the oil film that the rotors came with.  I did wipe the rotors before installing, but I guess it still had a little film if lubricant left over... Any advice will be greatly appreciated.
Thanks!
			Thanks!
 Any recommendations on what type of bushings should I go with?  Advance auto sells their OE style and are made of rubber.  I have read on this site that the poly ones are no good and make noise.  Any thoughts??  Thanks!
