Replacment Coil Pack?
Tampa T-Type
Is there any aftermarket Coil Packs that anyone recommends. I have 1/4 clearence above it due to intercooler pipe. Any gains felt after replacment?
We offer a High-Output Coilpack for the '86-7. From your comments, you have an '84-5?
If so, the '86-7 ESP Coilpack and Module can be used with an adapter harness. This set-up will offer you more clearance for your intercooler pipe and other performance benefits.
Hope this helps.
Car ECM changed to an 87
I assume this would be the correct harness already in place. How would you suggest I verify the pin outs?
