SignUp Now!I'm curious if replicas zr1 rims will fit under my grandnational..the backs will be 17x11 dont know the back spacing......and fronts is 17x9..............
thanks
you can do it with out amini tub just use wider spacers you could always sell the 2 fronts you have now and get a set of the front 17x8 from SLP then you would only have to run spacers on the back or get a set of 4 of the 17x8 fronts and and then sell a set on the board one with 17x9 rears this way you would also be able to play around with what we works best for you in the rear 17x9 or 17x11.
black monte........is those rims 17x9 all the way around? or is those the 17x9 front and 17x11 backs ? and if they are, whats the back spacing size and where did you go to get it????
theres are the rims i wanna mount on my car.
Please show me pics of a regal with 17x11's UNDER the car without a minitub
You can get them under the fenderwells but not cleanly under the car where you utilize full suspension travel.
The only car I have seen with 315/35 17s is minitubbed and sits right... not chicken-assed.... car is minitubbed and the outer lips are trimmed/rolled.
The rears are 17x11 (maybe 11.5) and the fronts are 17x9.5"; tires are 315/35R17 Nitto NT05R Drag Radials and BFG KDW 275/40R17 respectively. The car does not, and WILL NOT, have its frame notched. The rear wheel well lips will have to be rolled/flared out about 1/2" to comfortably fit the tires without the risk of slicing the sidewalls (current issue given the fact they were previously cut out). I will also be obtaining the longest wheels studs money can buy and running between 1/4" and 5/8" hub-centric spacers to make up for the offset in the rearend/body on frame. I have to test the suspension articulation to see what it needs.
The OP in that thread says 2 things, that the rear lip is rolled/flared, and that he had to cut out the inner fronts to make the 275s fit. I'd like to see more of the actual surgery.
Also take note that the car is missing the wheel trim. (so probably NO lip remains.)
More information would make this more useful.... Actual wheel width (he refers to 2 sizes, 11 and 11.5, backspacing(Should be between 4.75 and 5.00 inches), etc.
why dont you ask him..hes on both of these sites. i dont know about the cutting..since he said flair/roll the lips.
the wheel moldings have never been on the car..
Hey guys im pretty new with this. I want to know what is the wheel spacing for our gns. Trying to buy some rims for my car online. What would be the biggest and widest rim i can fit without getting running into problems. Thanks
