New Update on what's left:
1. Set of four T-Type rims with tires already mounted. Rims in very good shape just clean up and bolt on. Tires have about 3,000 miles on them, nothing wrong with them. $550 takes em, pick up only.
2.
3. Set of PTE Front mount IC pipes, dented but useable $80
4. One stock turbo, needs rebuild $60
5.
6.
7. One power steering pump/Steering box out of GN $75
8. One stock fan assembly $80
9. Rear end from GN with axles but needs posi unit & two brake lines $350 pick up only
10. One set stock lower control arms $25
11. One set stock upper control arms $25
12. One set rear tail lights- Right one has small crack on outside right side $75
13. Various interior pieces, rear pieces $40 takes them all
14. Gray rear trunk lid- needs lock assembly and black trim piece $50 pick up only.
15. Two Autometer mechanical gauges Oil Pressure # 2623 & Water temp #2607 never installed $35 a piece
16.
17.
18. Power antenna inside motor assembly tube only $40
19. One set rear opera windows- good shape $80
20. Deep tranny pan for 2004R $150
21.
22. Three stock fuel pressure regulators $10 a piece
23. One stock up pipe $25
24. One Bosch external fuel pump $50
25. One set stock injectors 80k on them $40
26.
27. Soft front brake shoes from Kirban never used $30
28. Negative batter terminal $25
29.
30.
31. Hard fuel lines that go into gas tank that sit on upper rear deck of car $25
32. One rear chrome bumper- fair shape $30 pick up only
33. One set stock axles $50
Stage Parts:
Stage 2 Parts for Sale
(4) Forged Flat Top Pistons, 6.5 length, 3.590 stroke, 30 over for Stage 2 heads mated to Titanium I-beam connecting rods $400
Buick Motorsports Stage 2 on- center front cover with water pump with crank trigger, water pump has electric fan pulley attached $200
Buick even fire crank trigger and distributor with alternator bracket $200
On Center dry sump oil pan for Stage 2, side lip is bent downward due to damage from hole being blown thru side of block, just bend lip back up and it could be used again, side of pan has 3 large blue AN fittings. $200
All prices don't include shipping, other parts pick up only.
