right front tire bad uneven wear??
tpabayflyer
Does the downpipe heat melt the right side upper control arm bushings??? I have a problem with my 87 GN wearing the inside right edge on the right tire like crazy..... TIA TBF
Could be bushings but also other worn parts.Are the ball joints tight.tie rod ends sloppy,blown shock,broken spring.Whens the last time it was aligned?
