rjc boost controller on duel port ATR WG?
3.8vsix
I order a rjc boost controller and was wandering how I could hook it up with using the air compresser regulator in the car.The way I have it now is the line between the compressor and bottom wastegate port is T'ed to the air compresser regulator then to the top port on the wg. Or will I have to use it with just the bottom port on my atr ext wg? My spool up has been real slow and I hope this thing will help.
thanks for any help!
the rjc boost valve did wonders for my spooling with my atr gate, made my 70 turbo spool like a 44. as long as you dont have any other problems ( ie exhaust leaks or a bad gate) it should make a big difference. run the rjc valve between the compressor housing and the side port of the gate. place the T to the "air compressor regulator" after the rjc valve, b4 the side port of the gate. dont worry about the port on the front of the gate, just leave it open, or put the original breather back on it.
Thanks for the reply. I got it and put it on. I personally could not tell any differance. Plus could not get it to go past 22psi. So I went back to the air presssure regulator it seems to be the same maybe a little better on spooling. Just my 2cents. If any one wants it I will take 40$ ship to your door. I'm sure it works better on the "stock" style wg's.
Travis, Consider it sold. Can you bring it to Farmington this Sunday, if your going.
That should save about $5 in shipping souldn't it? ;)
49-blues said:
Bird- do you have any pics of your rjc valve/wastegate set up ?
no, sorry , i have to get a digital camera soon. :o if you cant find any pics anywhere else let me know and ill borrow a camera.
